all done, but anything else should i do?
i started first doing this (pic taken from the net)
then decided to do the blanking plates and removal of egr,
before removal of nuts, to make it easier, i released the handbrake cable.
and off it is, and blanking plate on
i put a bolt to block the vacuum pipe that was going to the egr that you can see at the bottom of pic
and taped the cable that was connected to egr circled in red
is there anything else should i do? besides give the engine a good clean?
thanks
thanks
