anyone know a link on how to. re the above
jacked up the front and rear end tonight and found i have i little bearing play in n/s front and n/s rear bearings, done the front no probs but didnt even try the back untill i have looked into it.
also how much movement should there be in the stub sticking out past the bearing, i cannt here the bronze bearing rattle but the stub was quite loose
