Wheel Offset Chart & sidewall info
  • Wheel Offset Chart & sidewall info
    FOR THOSE OF YOU WHO HAVE WANTED WHEEL OFFSET INFO. ITS AT THE BOTTOM OF THE PAGE.
    http://www.tyresave.co.uk/fitment.html#TECH
    Sidewall Marking Explanation
    205
    Width of the tyre in millimetres
    50
    Height of the tyre sidewall as a percentage of the width. In this case 50% of 205mm. Also know as the aspect ratio.
    R
    Radial Construction.
    15
    The diameter of the tyre's inner rim in inches
    91
    Load Capacity of Tyre (See Load Table). In this case its 615kg
    V
    Speed Symbol. Indicates the max. speed for the tyre at full load. In this case 149.1mph.
    E4
    ECE type approval mark, which demonstrates the tyre has been tested as high quality by the European Regulatory Authorities. All Tyres sold by Black Circles carry this mark.
