Tps
  • Tps
    Having black smoke, lack of power and lumpy/misfire.
    Checked;
    Timing marks
    Fuel supply
    Vac pipes & leaks etc.
    Just done bench test on TPS and found a low reading on VTA/E2;
    Open 5.56 (within range)
    Closed 0.03 (should be 0.2 to 0.8)
    Does anyone know if this could be the problem
    and has anyone got one for sale
    Cheers Col
    PS; Is there any way to check the Intake air temperature sensor.
    All the best
