speedo fault
  • speedo fault
    Can anybody help with an infuriating intermittant problem? I have owned a 96 Kzn185 for the last three years, which up till now has been faultless. Suddenly, the speedo went dead. At the same time, the compass and 'rolling road' in the overhead console froze. After a while it all started working again. Then it did it again! And Again!! Occasionally the 'o/d off' light will also flash, though the o/d still works as normal. Crawling underneath, I can see that the drive is electrical (I assume it is the plug at the rear output shaft), but I need to know if there is any test I can do, or is there any item that I should test, or must I resign myself to throwing money at it, replacing various units until I strike it lucky (or worse, pay someone else to do it)? In short, HEEEELP!!!
