Say hello to my little friend!
  • zem_41
    replied
    Yes bolted to the back of the left head
    Leave a comment:
  • BUSHWHACKER
    replied
    Originally posted by zem_41 View Post
    Yep all done mate,
    Got it all wired in, checked connections to oil pressure switch, fuel pump.
    Started it and it fired nearly instantly but then dies straight away?
    Seems like the fuel pump isn't switching, and the oil pressure gauge stays at 100?
    Any ideas ?
    Is the body of the oil pressure sender earthed?
    Leave a comment:
  • zem_41
    replied
    Yep all done mate,
    Any ideas ?
    Leave a comment:
  • BUSHWHACKER
    replied
    Hi Vince
    I have lost the message you sent about where to connect the the temp sender wire to get the surf temp gauge working.
    Sorry
    The Surf's temp gauge wire is in the large white plug in the footwell, which I have here to send to you.
    Same goes for the reverse lights and speedo.
    Oh and what ratio do you put anti freeze in?
    To be honest I don't really measure it out, but it's around 50/50.
    As long as there's good colour in it then it'll be fine.
    T/case wiring arrived today by the way.
    p.s. did you modify and extend the two wire (green and red wires) speed sensor connection to the transfercase? It's part of the engine/transmission loom.
    I forgot to do that one and without it the transmission won't shift out of 1st gear!
    Leave a comment:
  • zem_41
    replied
    Leave a comment:
  • zem_41
    replied
    Hi Vince
    Sorry
    Leave a comment:
  • zem_41
    replied
    Sweet cheers dude
    Leave a comment:
  • BUSHWHACKER
    replied
    When you say the oil pressure switch wire, that's just to my new sender right?
    Yes, the fuel pump relay needs a signal (oil pressure) to switch over to constant running when the engine is running.
    The fuel pump primes the fuel rails when cranking, but won't click over to constant running until the engine fires up and the oil is circulating to trigger the pressure switch.
    The fuel pump will stop pumping fuel if the engine stalls when you hit a tree for example.
    It also means you can leave the ignition on when checking for any ECU codes.
    Leave a comment:
  • Sylux
    replied
    Oooh...exciting times
    Try and get a video...even if it's just a phone vid.
    BTW: What have you guys done with the redundant fan bracket? Have yous replaced it with a pulley/idler or something?
    Leave a comment:
  • zem_41
    replied
    Leave a comment:
  • zem_41
    replied
    Ok cool cheers buddy
    Yeah had a bit of trouble with hermes picking up, it didn't get collected till Tuesday so should be with you tmrw or Monday.
    Now I know why they so cheap, and just had another person I sold a honda blade headlight to message me saying it got broke in transit!!!
    Brilliant!
    Leave a comment:
  • BUSHWHACKER
    replied
    So big start day tmrw!
    I'm pretty much wired in apart from the wires around the steering column.
    Is there anything I need to be checking? apart from the obvious ie sump plug in, oil/coolant in.
    Will the bits your doin Vince stop me from starting?
    I know I should know this by now but is the surf ecu staying right?
    Cheers buddy
    The Surf ECU is redundant now, so either bin it or sell it.
    Connect the fusebox power wire to the battery, the permanent 12v wire and the ignition 12v wire, and the crank signal wire to the multiplug under the steering column, switch on ignition and make sure the check light illuminates.
    If it does then the ECU is powered up and ready for engine fire up.
    Did you connect the oil pressure switch wire?
    Fuel pump wired?
    The transfer wiring doesn't affect engine starting/driving, but you will have no speedo.
    p.s. Those plugs haven't arrived yet by the way.
    Leave a comment:
  • zem_41
    replied
    Cheers buddy
    Leave a comment:
  • zem_41
    replied
    Cool
    10-4
    Leave a comment:
  • BUSHWHACKER
    replied
    Ok cheers Vince, is not possible to cap both off?
    Thanks for the heads up buddy
    They need to be linked together so the coolant can flow properly.
    Leave a comment:
