golly needs a part
  • golly needs a part
    greetings all you surfers
    i am in need of a part am gona try to intercool my truck as the turbo is so close to the inlet pipe that passes over the head there aint enough room to put 2 bends in where i need to so am after the aluminium pipe that passes from the turbo and up over the cylinder head so that i can cut a bit out and weld it back up so i can get my intercooler pipes on at the angle i need.
    so if anyone has one i could buy it would be great an if it works hay we could do an intercooler kit for anybody else that wants 1.
    our surf is 2nd gen 3ltr kzn130 am going to put the cooler where the ac rad is as i have a window and a sunroof so dont need ac will turn that into a compressor so i can air down when crawlin over rocks in the quarry gollygone
