How important is it to get aircon service?
and is there a aerosol can that will clean and service the aircon
Thanks everyone I cured my oil leak after many months it was the inlet manifold gasket also cured the clonks in stearing stops
still can't figure out my turbo light coming on and works ok when cold
but as soon as it warms up the light goes out and it doesn't have the same
accelaration,
sometimes it lasts for longer
but when i stop and remove ignition key and start up again it goes out,
there are no air or oil leaks and have checked for loose leads will a diagnostic tell me what problems might be?
oh well trudging the road to happy destiny
I love my surf
I have found in Halfords a product called Comma it cost £11.99 it is a aerosol can that you put inside the care with the aircon on whilst running the car at
idle speed with all windows closed and no one inside placing the aerosol in rear passenger floor you press the can to lock position and shut door, it sprays out a jet of spray that eliminates bacteria & viruses.. I have done my surf it seemed to smell very nice but hard to tell if it worked or just a gimick the idea being that the aircon sucks up the vapour into the system..
accelaration,
I love my surfI have found in Halfords a product called Comma it cost £11.99 it is a aerosol can that you put inside the care with the aircon on whilst running the car at
