front drive shaft play
  • front drive shaft play
    Hi everybody, first time post. i have always found the forum extremely helpful without having to post but now i need advice. I thought i had a wheel bearing going but checked it and it seems fine, the only play i can find is on the drive shafts, how much movement is acceptable. the car is a 96 gen 3 with semi floating axles. Cheers hoping for advice from you guys
