Ooooo
May put mine up for sale . Watch this space
serious conversion questions
If you know a 3.0 is enough, just get shut of your 2.4 and get a 3. There are plenty about and if you choose wisely, you won't have any lingering snagging to do which may result from a cheap engine swap.
Leave a comment:
No.Originally posted by Robmatthews View Postis that all the wiring done then? for speedo for instance?
Leave a comment:
is that all the wiring done then? for speedo for instance?Originally posted by BUSHWHACKER View PostI do mail order, plug and play Lexus engine looms now for £150. Send me the loom with all the ECU plugs and I'll send it back with it's own fuse box and relays, then it's only four wires to connect to get the engine running.
If that helps.
Leave a comment:
You could always buy mineOriginally posted by animal View PostAfter talking to the wife about a few things , we have decided the surf is a must have vehicle , but it needs more power .
But it needs more power .i know the easiest option is to pay vince to put a lexus v8 in it . but that is not a option as i cant afford that sort of money .
So the questioins now are ..
1, what other engine options are there to replace my 2.4 lump
2, how hard is it to convert it to a 3 litre diesel (i.e what would need changing other than the engine itself)
any help would be appreciated
Leave a comment:
Yep! Spotted you a mile off (quite literally) and caught up in no time!Originally posted by animal View PostYes you biatch. Bet it looked good our trucks stood next to each other at the lights though
I always think they look bigger moving... it's not often I get to look square on at another vehicle to the side of me, then to the back of me, and then just a dot in my rear view mirror...
Leave a comment:
Originally posted by yoshie View PostBut Vince says only 4 wires to go, even I might manage that without a fire.
And when you've finished fitting it Vince will be able to sell you one without all the melted cables ...
Leave a comment:
Hmm the possibilities for an auto electric eejit like myselfOriginally posted by BUSHWHACKER View PostI do mail order, plug and play Lexus engine looms now for £150. Send me the loom with all the ECU plugs and I'll send it back with it's own fuse box and relays, then it's only four wires to connect to get the engine running.
If that helps.
Leave a comment:
Leave a comment:
