I have an intermittent electrical problem. Vehicle engine starts ok for some number of times, then inexplicably, will either stop when slowing down or idling, and will not restart for a while, or after sitting for some time, will just not start. Starter relay appears to be locking in when turning on starter switch, but starter solenoid does not engage.
Additionally, the battery appears to go flat for no reason, which three mechanics have stated the battery needs replacing (so replaced twice with new battery, but has not solved the problem) Seems to indicate a battery drain somewhere, but no one seems able to find it.
Thanks for help
Thanks for help
