heres the write up to fitting the plasma gauges which i recently bought off eblag. first then whats in the kit.
all gauges
1x oil pressure
1x fuel
1x batt
1x temp
1x speedo gauge
1x rev counter
1x wiring loom
1x dimmer switch
1x instructions
kit needed:
1x phillips screw driver small electrical type
1x hairdryer
2x tea spoon
1x drill bit/ stanley knife
from there then you need to get the gauge cluster out of the dash. im sure there is write up of that already so ill just go through from having the gauges out.
first off what i did was lay everything out with the gauges in front of me then proceeded to take all the old led dash bulbs out then i took the front glass/plastic facia off the dials to do this there is several clips that hold it on to the rear of the gauge cluster i used the screwdriver to release them and gently spereated the cluster. heres the pics below upto this stage.
all gauges
1x oil pressure
1x fuel
1x batt
1x temp
1x speedo gauge
1x rev counter
1x wiring loom
1x dimmer switch
1x instructions
kit needed:
1x hairdryer
2x tea spoon
