pump timing
  • pump timing
    does anyone have a pic of the cambelt layout/timing for a 2.4td i think the garage who done my head job may have put pump timing out by a country mile
    just found a pdf link on here will try sort it if not send to a diff garage
    Hi Les,
    Try this, all marks are shown,
    Crank @ 12 o'clock, cam @ 6 o' clock, pump @ 12 o'clock.
    piccy no2
    http://www.toyotasurf.asn.au/techsite/timingbelt.htm
    Hope this helps.
    Gman.
    If it aint broke, keep goin' till it is.
      Originally posted by GRASSMAN View Post
      Hi Les,
      piccy no2
      Hope this helps.
      Gman.
      yeap that's the one i downloaded pdf from thank-you sir
        Dealt with a couple of 2.4's with the cam 180 degrees out . Still run but will not rev and really smoke.
