www.hiluxsurf.co.uk
Search this site:
Google:
Yahoo:
MSN:
Home Surf FAQ
Old 17th May 2017, 07:44   #1
Peebles05
Registered User
Peebles05's Avatar
Default Ask for Help
Hello
I have a big problem with my Hilux 3.0 Gen. 2.
I drove yesterday about 200 miles with a 2.0 ton heavy trailer. Whenever I had to drive up a mountain the engine became very warm, (almost in the red area) also the warning (A/t temp) went on. I always drove to parking lots to let the engine and gear cool down.
There is enough water in the cooler and in the reservoir.
Now to my question, what can be the and what can I do to fix this error, as I have to get away with the heavy trailer again next week.
Thank you very much
Greeting
Burkhard
__________________
Red Monster, KZN130 3,0 Litre Diesel
Peebles05 is offline   Reply With Quote
Old 17th May 2017, 08:30   #2
NiftyNev
Senior member
Default
Do you have an external transmission cooler? Transmision fluid is cooled via the radiator bottom tank. Towing can add much more heat to the transmission fluid and this adds extra heat to radiator, which then may not be able to cool the engine properly. Maybe adding an external cooler will solve the problem. This cooler is best fitted to the transmission line before radiator so it cools the fluid before it heats up the radiator.
Nev.
NiftyNev is offline   Reply With Quote
Old 17th May 2017, 14:21   #3
Bogus
Plastic doesnt rust
Bogus's Avatar
Default
What Nev said, plus, do not tow with od on unless its a nice long flat. every time the torque converter comes out of lock up, and thats going to be a lot when towing a heavy trailer, you are adding heat to the ATF which in turn adds heat to a cooling system that is already busy. An external cooler is an easy fit though and you dont need to be overcomplicated about it if youre in a rush, as long as it catches a bit of airflow it will be a big help. You can always get more scientific about it before your next big haul.
__________________
Сви можемо
Bogus is offline   Reply With Quote
Old 17th May 2017, 17:23   #4
The Boo Crew
Registered User
Default
I would be checking your rad to see if its full of crap!
__________________
Old enough to know better but then again.....
The Boo Crew is offline   Reply With Quote
Old 18th May 2017, 08:16   #5
NiftyNev
Senior member
Default
Quote:
Agreed. Also check the Viscous Fan is operating correctly.
Nev.
Old 18th May 2017, 09:05   #6
tweak'e
Registered User
Default
as above
check fan
check or simple replace, the radiator.
fit external trans-cooler, the biggest you can squeeze in (radiator type and mounted the right way).
tweak'e is offline   Reply With Quote
Old 22nd May 2017, 18:31   #7
Peebles05
Registered User
Peebles05's Avatar
Default
Hello
Thanks for the helpful answers.
I've done it now (finally) to look it up. So I got the engine warm and then I could stop the fan (with the engine running) with my hand. I even made it without any effort to turn it against its actual running direction (well said, while the engine was running) the engine had operating temperature.
So I think the viscous fan is broken.
I will reorder this and a transmission oil cooler. As everything is there, built in and I have made a ride with a trailer I will report it.
Greeting
__________________
Old 22nd May 2017, 19:06   #8
tashtego
Registered User
tashtego's Avatar
Default
This is what you need:
http://www.roughtrax4x4.com/aisin-vi...210-67010.html
Good luck!
tashtego is offline   Reply With Quote
Old 23rd May 2017, 04:45   #9
tweak'e
Registered User
Default
Quote:
Originally Posted by Peebles05 View Post
Hello
Greeting
i would not try to stop a running fan with my hand
easy way is to turn engine off, if fan keeps turning for a bit then its faulty.
no need to replace the fan hub. they jest need the silicone oil replacing. there should be a thread on it around here somewhere. cheap and simple to do.
Old 15th June 2017, 21:23   #10
Peebles05
Registered User
Peebles05's Avatar
Default
So,
Now after a long time (a little bit of work) I managed to see my surf completely. Now I have an order list for roughtrax4x4 which costs me 1400 pounds. And these are only spare parts, among other things I also change the exhaust and make all the brakes as well as the rear shock absorbers with springs. The timing belt and the water pump but also a few accessories, such as the white indicators in fenders and the underrun protection. I'm just honest here, a car dealer offered me a Discovery 3. And I was tempted to accept the offer, but I can't, I love the Hilux and he has never let me down so much, and I can fix it to 80% myself thanks to your help. I am and remain Hilux driver as well as classic Mini driver (my wife's).
I am already happy when 70 kg of parts arrive at me and I can dedicate myself fully to my Hilux.
I also want to install a snorkel, but also look for the rear spoiler for the Hilux.
Another thank you to all forum friends
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright 2004 the webmaster
   Address - N White, PO Box 278 Stevenage, Herts, SG1 1ZU, UK
All information and images on this website remain the property of the owner and no use shall be made of them elsewhere in whatever format without the express permission of the owner. All Corporate trademarks are the property of their respective owners.
You may freely link to this website however ownership of material remains as stated above.
 Contact us: toyota@hiluxsurf.co.uk
