Can my rear axle be saved?
  • Can my rear axle be saved?
    Can it be saved? If I drop the axle, shot blast it and repainted with red lead, stone chip and paint?
    [/URL]
    Not allowed 1) tools 2) matches 3) sharp objects
    [/URL]
      [/URL]
        It's going to depend on what you find under all that crud once its been blasted, but so long as you know someone than can, or are able, weld anything's possible
          It might be cheaper to get one of a breaker and swap the diffs if different.
            If I get one from a Gen 3 shouldn't it be the same?
              Diff.
              You would need to check the ratios to be certain.
                You would need to measure the width as well.
                  I should point out at this point that I am not allowed near:
                  1. Sharp objects
                  2. Tools
                  3. Matches
                  So I don't understand why all Gen 3 rear axles are not the same? Why would they have different ratios? How would I know?
                  And why aren't they all the same width?
                    Non of the pics are working, so I'm not sure what the problem is and what year surf it is.
                    I did remove a perfectly serviceable axle housing off a Gen 3 though which I still have spare, I also have a diff carrier from an landcruiser.
                    what is the actual problem / year?
                    More Lift.
                    More Tyres.
                    More Engine.
                      Funny, the pictures were fine yesterday!
                      The problem is rust, then more rust, with rust on top, an extra serving of rust on the side and then more rust. In a word, rust.
                        Axle housing should be the same but diff ratio depends if it come from a manual or auto. If yours is auto and you get another auto rear axle then it should be same ratio. Maybe look for the rear axle housing without diff and swap your diff in, if you know someone with a bit of mechanical knowledge.
                        Nev.
                          Yup, pics are working again today!
                          Jesus, that is rusty! watch out for the upper arm mounts, they tend to gather water at the bottom and rot though, failing totally.
                          What is the chassis like? another failure point is the lower arm brackets where they meet the chassis.
                          if you choose to rehouse the axle (not too bad a job) I have a decent spare casing. it's not too much of a job to swap over, and you can do the axle seals at the same time and paint it up nicely with POR15 or similar.
                          More Lift.
                          More Tyres.
                          More Engine.
                            Thanks Charlie, it would be a great help if I could drop by in the truck one day to talk to you about it. I'm in Paddington so I'm not a million miles away from you.
