Gen 2 to go...
  • Gen 2 to go...
    206,000Km (130,000 miles I think).
    Just had its MOT 3 or 4 weeks ago.
    Needs a front diff as I broke a tooth of it last summer, 4WD works in every other respect. Vehicle can be driven in 2WD mode without issues.
    Advisories on the MOT:
    Corrosion to rear fuel pipes (I've not found it, but has been on the last 3 MOT's).
    Surface corrosion to chassis at the rear.
    pin hole in the exhaust.
    Everything else works, general wear and tear as per a 20 year old 4X4.
    Steel wheels (pictured) are 33" tyres on the back (15" steel wheels) and 265's on 16" steel wheels at the front.
    Alloy wheels with worn 31" tyres on also included, as per the spare wheel.
    2" body lift
    2" suspension lift on the rear, front torsion bars adjusted to suit.
    Both front lower ball joints new in the last 18 months.
    ARB drops links done at the same time.
    A box of assorted spare bits, switches, relays and window motors included in the sale.
    Currently SORN.
    Now sold.
