Calling those with 2nd gens with 2" body and 2" suspension lifts...
  • Calling those with 2nd gens with 2" body and 2" suspension lifts...
    Hi all
    If you've got a 2nd Gen with 15" wheels and a 2" body and 2" suspension lift, could you possibly do me a favour and measure the distance between the top of the metal wheel and the underneath of your wheel arch, front and rear?
    I'm trying to figure out whether the rear springs I have are standard or extended. They're meant to be standard but seem to give a taller ride height than the extended ones. It would be good to get a sense of the rim-to-arch gap other people are running.
    Owen
    Anyone?
    Owen
      I have a 2in body and sus lift but 13in rims and 33's, wouldn't have thought too many 2nd gens have 15in wheels fitted.
        I've got exactly what your after, I'll measure it later for you and give you the numbers
          Are you sure about this?
          Nev.
            So mine is front 16.25" and the rears are 16.5" hopefully that helps
              Nev.
              your right! I'm old and get confused, f##k knows where I got 13in from,
              mine are 15 with 33's, probably time I stopped posting without thinking about it
                Cheers fellas, Popeye would you be able to measure yours if you get a min too? I'd be keen to know your numbers!
                Owen
                  Also ThatGuy, do you have any aftermarket bumpers, etc, or are you running relatively stock weight front and rear?
                  Owen
                    We all have those moments occasionally.
                    Nev.
                      have your torsion bars be wound up at the front?
                      SWIFT AND BOLD
                        Owen
                        Will do mate, just had my pills and pint of Sanatogen so i'll do it in the morning
                          I have 45cm at the rear and 40.5 front, however I have LC springs on so I think the rear is just over a 2" lift, more like 3"
                            Thanks chaps, useful to know. Do you run stock bumpers mate, or have winch, rear carrier, etc on?
                            Owen
                              Owen
                              Myself I have a winch but not a winch bumper and a rear swing out carrier, 9it used to be under slung but I prefer the swing out one).
