Rear diff problem
  • Rear diff problem
    Hi, I recently replaced the rear diff (LS) on my 1993 2.4 surf with a like for like replacement. The new diff is now making a clunking speed on cornering in low gear. It's fine at higher speeds. The new diff was in good nick and was a relatively easy job(or so my mechanic tells me!) We are a bit stumped as to the exact problem (fault in the diff? Anti-roll bar? Prop shaft? Any help very much appreciated
