Rear Coil Spring Sizes
  • Rear Coil Spring Sizes
    Hi all
    I have a 1993 2.4surf. When I bought it, it came with two spare, good condition rear coil springs. I want to fit these as the ones on it are rusted and flaking quite bad. The question I have is are these springs standard springs for my truck, there is a number stamped on each one:
    T252152 - this one measures 40cm high / 17cm diam on top and 13cm dial on the base.
    T252153 - this one is the same diambut only 39cm high???
    The truck has had a 2 inch body lift but as far as I can tell the suspension is still standard.
    Any help appreciated
    Lea
    the tallest, it goes on driver side
