2.4 2nd gen. bits for sale
  • #61
    Originally posted by rossyroo View Post
    injuectors?
    see my post on parts wanted
    sorry in delay on answering, i had being away, do you still want them? so i can have a look
    • #62
      Bump!
      • #63
        Fuel Rail
        My Mechanic snapped my fuel rail when checkign the injectors (before replacing the turbo, fuel pump, lift pump etc. etc.)
        Do you still have the fuel rail?
        • #64
          the one that connect all injectors?
          • #65
            yeah - sorry but I got one this morning.
            First post so been tryign to get that uploaded a while
            thanks
            • #66
              no worries!
              • #67
                change of mind
                i have changed my mind and not keeping anything,
                so;
                bump!
                • #68
                  What colour is it?
                  • #69
                    mmmmmm!!! the most color you can find on a surf!!!
                    Burgundy!!!!
                    • #70
                      Do you have interior trim?
                      Looking for the little panel that has the map holder on it. If you can remove the two plastic plugs without scratching it. It's not hard. Done it countless times without issue...but the last time I got ####ed off and scratched mine!
                      Also the grey trim beneath the radio. Easy to remove but mine's got phone holder holes in it.
                      • #71
                        map holder? do you have a pic of it?
                        • #72
                          I'll get one Also of the radio surround bit.
                          It's the pocket under the radio/in front of the gears.
                          • #73
                            oh, i see, i will check later, when i finish what i'm doing. i got the feeling that the radio surround someone had butchered, but check later to be sure. and will put some pic of it, if you are happy the way it is
                            • #74
                              is this what you mean?
                              • #75
                                That's one of them. But it looks butchered, like you say. However, now you have it off...can the black separate from the grey easily? I can't remember.
                                The other bit is below that bit. The map holder pocket thing.
