my surf v8
    Might have to call in aswell, I'm only in Northumberland
      Ill break out the spare disposable bbq
        Originally posted by Reece2.4 View Post
        cheers guys
        sylux did you get a unit down the westline??
        I did, yeh
        Been sorting out the last few days. Need to clean it up and get it sorted. Waiting for tomorrow so I can ask Phil about skip
          nice one
          on a separate note is the gearbox completely drained when its removed from the engine because alot of atf came out of the torque converter and if thats the case how much is needed to fill it up? bear in mind it will be run with a aftermarket oil cooler so that will be part of the capacity too
            engine begins trial fitting phase, so far there is only one problem and thats the steering column hitting the manifold
              I think V8 Soarer 'Log' manifolds fix that. Or, move the engine back or to the N/S.
              • #22
                yeah going to give it a jiggle about tomorrow and see what I can do with it
                • #23
                  What times are you normally around? Would love to walk over.
                  • #24
                    Ill be down pretty much all day on saturday, Ive seen which unit your in now with the skip outside so if Im driving past and its open Ill come see whats up
                    • #25
                      • #26
                        Good progress buddy
                        Looking good
                        I had a similar issue with mine, I massaged the manifold slightly and it's also possible to remove the rubber shock part of the steering column and replace with some bolts ill post a photo.
                        ALL THE GEAR!............no idea!
                        • #27
                          Steering column
                          Bit of a funny angle but u shud b able to see.
                          • #28
                            got the mounts done today with all the clearances sorted, its close though but everythings sitting pretty
                            ended up grinding the heatshield bolt hole down so it misses the steering column and moved it over a tad so theres about 10mm gap, theres about 10mm too on the manifold/torsion bars and the cam end/handbrake
                            dropped the fuel tank too and started that, all the brake lines above it are solid so bonus
                            • #29
                              Yeah my clearances are about the same mate
                              Happy days
                              Keep up the good work
                              • #30
                                Where do the 3 wires go from the alternator on the modified loom
