2.4 2nd gen. bits for sale
  • #46
    oops! very sorry, just noticed your post. are you sorted with your speedo sensor?
    • #47
      3rd gen. clear wing indicators sold.
      still got same bits!
      • #48
        just realized i got a centre cap wheel of a 3rd gen. will post a pic of the cond.
        • #49
          Radiator Fan Sensor & coolant Temp Sensor
          Hi Bud, I don't suppose you have a Rad Fan & Coolant Temp Sensor by any chance....?
          I got engine check light on (code 4), and when changing some coolant hoses, accidently punched the Fan Sensor Switch ....
          Have to say I did try super glueing it back exactly where it snapped off but the fan don't kick in....
          And some prices if you have them
          Regards J
          • #50
            Regards J
            can you post a pic of what i should i be looking for under the bonnet? so i don make mistake of what i be taking off.
            thanks
            • #51
              Sensors
              hi there, thanks for quick reply, i can't get the pictures from my phone to the pc, thinks its my phone.
              The Rad fan sensor is the one on the thermostat housing, if your standing at the front of the truck its the one lower down closest to you.
              Ok, the Temp Coolant Sensor is located just above and to slightly to the back of the starter motor, proper tw@ to get to reading some of the threads on this site.
              Gimme half hour, am going to take some pics with my camera.
              thanks
              Hi again, coolant temp sensor is located just above the phillips screw on the starter motor on the pic to the left.
              The Rad Fan Sensor is directly under the hose from thermostat housing at the front of the truck...hope this helps....
              thanks for your time J
              • #52
                hi buddy
                do you still have the steering wheel and exhaust???
                • #53
                  thanks
                  Hi Bud, don't suppose you had any luck with the Sensors ??
                  Regards J
                  • #54
                    thanks
                    sorry they aren't good, very sorry i didn't answer earlier
                    • #55
                      Originally posted by sy281184 View Post
                      hi buddy
                      yes i do
                      the wheel good cond.
                      the exhaust very little use, full system from turbo till the end
                      email me to
                      thejoke.acosta@gmail.com
                      • #56
                        Have a non leaking fuel pump for 2.4 efi?
                        well, that was a bad idea!
                        • #57
                          do have both the engine mounts for sale?
                          • #58
                            Not a problem, thanks for your time
                            Regards J
                            • #59
                              bump!
                              • #60
                                injuectors?
                                see my post on parts wanted
