Seat upholstry/fabric cover for reg seat
  • Seat upholstry/fabric cover for reg seat
    I would love to redo my drivers seat and was wondering if I can get spares for the original seats (non Recaro) by any chance anywhere?
    Refurb seats
    Mathias,how do.
    Not too sure what you actually want to do ,I am in the process of getting the right side of the drivers seat (backrest and squab)re upholstered,as this nearly always wears.The original material isnt available for mine,but I found some at a firm in Manchester (£10 a metre),near perfect match to the headlining though,not aproblem as I have seat covers fitted anyway.
    The firm is called SEGAL and their number is 0161 834 7994,just off Deansgate in Manchester.There is also a refurb supplier in Middlewich(near Crewe)but not sure of their name.If it is the foam part of the seat that has deteriorated (gone crumbly) then you may have to find some odd bits off a market stall and glue, then shape by hand with a sharp knife or heated blade.
    I will gladly send you a piece of the stuff I have if you want to compare,but as I said the original is possibly available from Toyota but at a price.If you want to have a look at the material I have,reply here or my email is
    millydash@live.co.uk
    Dont ask,my daughter set it up for me,Regards, Alan
      Hi Alan,
      thanks for your reply!
      I actually would need the foam part of the bottom seat too. The upholstery is worn on the right wing of the drivers seat as usual but the foam under it doesn't feel comfy any more.
      Maybe I check for some Recaro seats, a bit of a thing to get out of them as they are meant to keep you proper in the seat but top quality and spares usually available for a long time. Plus really comfy on longer journeys!
      Regards
      The Hoffi
        seats
        Dont know if you sorted your little problem but I am told that the two front seat squabs,the bit your ar"e fits on are interchangeable,wont solve the problem but it is a quick fix ,you could try and get a replacement from a scrapper,will keep my eyes open 4 u,I need one as well,Alan
          Haven't done anything so far, other projects needed attention too!
          The idea with the passenger seat is quite good, will check for a scrap one too. Thanks for that!
            Toyota list a seat base foam:
            http://www.toyodiy.com/parts/p_J_199...QT_7151.2.html
            Notice that LH and RH foam have a different part number.
            Although who knows if ours are a seperate type. I will wait until I find a passenger seat from a LHD 4runner for good foam....
            I too need to redo the sides of my drivers seat which is a very dark blue, nearly black, is this the same colour as yours?
            If so do you have a reference for the fabric so I could order it?
            http://www.segalmotortrimmings.net/
              Seat covers
              Pat,Lord above,is that price in Dollars American or Canadien.The material I got is a darkish grey,slight dogtooth pattern,very like the headlining in my surf,I will try and put a photo on here if you like.The site you have quoted is the correct one,click on headlining,its the one shown as misc on their website,I think the code is HL53.If you ask nicely they may send you a sample,if not let me know and I will post you a small piece of mine.The foam bit you could make yourself,its only small bits glued over each other.Let me know about the headlining,Alan
                Cheers but mine is a very dark blue almost black.
                As I live in France I will eventually get a LHD passenger seat and then try to make a seat with the french foam, or just get decent covers
                http://cgi.ebay.co.uk/TOYOTA-HILUX-S...item3cb612d2b8
                ... but ebay scares me.
